Today I did the edge prep work on the top and bottom panels of the rear baggage wall as well as the forward side covers. I then riveted pop riveted the shoulder harness cable wear blocks. I also riveted the nutplates onto the forward baggage side panels. These will be removeable to allow access to the flap actuator mechanism.
Edges polished on both both rear baggage wall panels
Installing shoulder harness cable wear blocks
Forward baggage side panels-edges polished & nutplates installed
