Dan's Web Site
Date:  11-9-2004
Number of Hours:  3.00
Brief Description:  Debur/Dimple/Edge Prep Bottom Skin
After the primer dried I riveted nutplates onto the F902 forward bulkheads and installed the rudder cable snap bushings. I then started working on the forward bottom skin. I used the soldering iron to remove the plastic around the rivet holes, deburred everything and then dimpled the skin using the C-Frame tool. The last thing that I did today was debur and polish the edges of the bottom skin.
F902 forward bulkheads with nutplates and snap bushings installed
Forward bottom skin deburred and dimpled
Edge prep complete
Edge prep complete
