After the tank was clecoed to the wing, the joint plate was drilled for the screws that will secure the tank to the leading edge. The next step was to match-drill the tank skin to the ribs and baffle. This went fairly quickly but you definitely need to be careful here so you don't drill into the spar while match drilling the skin to the baffle.
