Brief Description: Drill Ribs to Spars and Reinf Plates
I back-drilled the spar reinforcement plates on each end of the two spars. I then clecoed the end ribs and nose ribs in place as well as the forward skins. I wanted to make sure I had everything oriented correctly. I then match-drilled the ribs to the spars and reinforcement plates.
