Dan's Web Site
Date:  1-10-2012
Number of Hours:  1.00
Brief Description:  Left Wing Tip - Micro Bottom Reinforcement Strip
This morning I sanded the bottom inside flange of the left wing tip along with the aluminum reinforcement strip. Then I vacuumed up the dust, cleaned everything with Acetone, and mixed up a small batch of epoxy with micro in it. I then used a small paint brush to spread the micro on both the wing tip flange and the aluminum reinforcement strip and clecoed everything together. The sledge hammer is just providing a little extra clamping force in between a couple of the clecoes where the aluminum strip was puckering a bit.
Left wing tip - bottom flange and reinforcement strip sanded
Left wing tip - bottom flange and reinforcement strip microed and clecoed together
