Brief Description: Rivet front spar and center rib to skin
I clecoed the skin to the front spar and rib assembly and then riveted the skin to the spar and center rib. I used the flush rivet set at about 40 psi. All of the rivets were easily reached with the bucking bar in one hand and the rivet gun in the other.
Skin clecoed to front spar and ribs
Right side of skin riveted to front spar and center rib
Left side of skin riveted to front spar and center rib
