Dan's Web Site
Date:  5-16-2005
Brief Description:  Cleco / Match-Drill Wing Root Fairings
Today I worked on the wing root fairings. These were awkward to work with. I ended up removing the most inboard fuel tank-to-spar screws on both the top and bottom of the wings. I then used these holes to stretch and bend the wing root fairings into place. Once this was done, it wasn't too hard to match-drill everything. I don't really like how the bottom meshes up with the fuselage. Not much support under there right up next to the fuselage. Perhaps I just need a cleaner, tighter bend along the leading edge.
Left wing root fairing clecoed and match-drilled
Right wing root fairing clecoed and match-drilled
