Brief Description: Drill Inboard Z Bracket; Remove Leading
After the #19 holes were drilled in the joint plate I drilled the holes in the inboard Z bracket using the pre-punched rib and baffle holes for a guide. Then the leading edge was removed to provide access for drilling the same holes in the outboard Z bracket.
