Brief Description: Route Wire for Tail Strobe and Elevator Trim
Today I routed the shielded 3 conductor 18awg wire for the tail strobe from the aft fuselage to the Whelen power supply that is mounted just behind the baggage compartment wall. I also routed the 5 conductor 26 awg wire for the Ray Allen elevator trim servo from the aft fuselage to the sub panel. Everything was secured via tie wraps to the Click Bond mounts under the longerons.
Wire for tail strobe, OAT, and elevator trim tie wrapped to Click Bond mounts along right longeron
Tail strobe wire crosses over F707 bulkhead to left longeron and down to Whelen power supply
