Next I routed 20awg red and black power and ground wires from the flap position module to the panel along with two 22awg wires for the extend and retract functions that will connect to the switch on the panel. I also installed the flap position sensor onto the flap motor shaft. Unfortunately I didn't get a picture of this and how the notched pin mounts to the moveable portion of the shaft and slides through the sensor that is mounted to the fixed portion of the shaft.
Power, ground, retract, and extend wires routed from flap position module to panel
