Dan's Web Site
Date: 8-30-2007
Number of Hours: 2.00
Brief Description: Wire Flap Position Module and Test
Today I mounted the flap position module to the vertical support channel and connected all of the wires. The 4 wires are routed up the channel, under the F705 bulkhead channel / seat back, through the F705 bulkhead and under the right longeron up through the sub panel and to the flap switch, power buss, and ground tabs. All of the wires are secured with zip ties. I had a lot of fun playing with the flaps,,,lowering them 1 notch, then another, then full flaps, and then retracting them with the switch on the panel. Works like a charm!
Flap position module wired and mounted to the vertical support channel
