Brief Description: Install Click Bond Tie Wrap Mounts
I purchased a bunch of Click Bond tie wrap mounts while at Oshkosh this year. I absolutely love these things. No need to drill any holes. The adhesive is so strong there is no chance of these things ever pulling off and they make securing wire bundles a piece of cake. The adhesive is a 2-part compound that provides about a 10 minute working life and the little plastic jobs have double-sided tape on them to hold the appropriate pressure against the mount while the adhesive fully cures over night. You just press down on the center and they click into place with the correct amount of force. I placed two of these between each bulkhead under both longerons throughout the aft fuselage. The left side mounts will be used for the static line and the right side mounts will be used to secure wire bundles. I need to order some more of these!
Close up of Click Bond jig that holds the mount in place while the adhesive dries
Click Bond mounts glued under both longerons all through the aft fuselage
