Brief Description: Install Dynon OAT - Outside Air Temp Probe
The Dynon EFIS manual suggests a couple of places to mount the OAT - outside air temperature probe. I decided to install the probe underneath the horizontal stabilizer on the right side of the fuselage. It will be away from any heat sources and protected there. Installing the probe involved drilling a hole in the skin and feeding the pigtail through and then installing the plastic nut with loctite.
Dynon OAT installed under right side of horizontal stabilizer
