Brief Description: Install Headset Jacks and Route Wires
Next I installed both the pilot and co-pilot headset jacks using the fiberglass insulating washers from B&C to prevent them from being grounded against the airframe.
The wires for the pilot jacks were routed underneath the F-705 bulkhead channel / seat back rest and then through the F-705 itself and up the right side under the longeron to the sub panel. The routing for the co-pilot jacks was a bit simpler and just needed to pass through the F-705 bulkhead and up to the sub panel.
Co-pilot jacks in place and the wires routed up to the sub panel
Pilot jacks in place and the wires routed underneath the F705 bulkhead channel and up the right side
Wiring for all of the jacks routed through the F-705 bulkhead and up the right side to the subpanel
