Dan's Web Site
Date:  6-4-2007
Number of Hours:  0.50
Brief Description:  Wire Starter Contactor to Ignition Switch
I used 20awg to wire up the starter contactor portion of the ignition switch. The BAT terminal is connected to a 7.5 amp fuse on the main buss and the S terminal is connected to the starter contactor.
Ignition switch with 20awg wires to main buss and starter contactor installed
20awg running from 7.5amp fuse on main buss to ignition switch
20awg wire from ignition switch to starter contactor
