Brief Description: Enlarge J1/J2 Slots in Sub Panel For Audio Cables
When I originally cut the slots in the sub panel for the J1 and J2 connectors for the audio panel they were just a bit too high which caused a lot of strain on the cables and connectors. I decided to remove all of the radios and then use a sanding drum in my beefed up Sears version of a dremel tool to round out the bottom of the slots. This lowered the cables about a half inch and provided for a much better transition through the sub-panel.
Sub panel slots for J1 and J2 audio panel connectors enlarged on bottom for cable strain relief
Forward view of the enlarged J1/J2 slots in the sub panel for the audio cables
