The next thing I worked on was wiring up the battery buss. I ran 14awg directly from the positive terminal on the battery to the battery buss. The other wire coming off one of the fused tabs and protected with a 10amp fuse is for the alternate feed to the E-buss.
Battery buss supplied via 14awg directly from the battery. Other wire is for E-Buss alternate feed
