Brief Description: Wire Fusible Link & E-Buss Alternate Feed Switch
Today I installed the fusible link that I made yesterday (18awg wire with 22awg fusible wire) by bolting one end to the stud on the main buss and running the other end to the master switch. This will be used to protect the wire between the buss and the 5amp breaker that will be used for the crowbar over-voltage protection for the alternator field.
I also installed 14awg from a 10amp fuse on the battery buss to the alternate E-buss feed switch, and then from the switch to the E-buss stud. I replaced the small boot on the E-buss stud with a larger one.
E-Buss alternate feed switch is wired, Fusible link is installed from main buss to master swithch
