Next I bolted the electric Facet fuel pump to the cabin side of the firewall. Then I decided to install all of the fittings on the Van's gascolator. I used EZ-Turn on all of the pipe fittings. I also capped the top ports of the transducer manifold since I won't be using these at this point.I purchased a small electric valve for the priming system. This will eliminate the need for bringing more fuel lines into the cabin. I think I will plumb this to the other side of the gascolator but I'm not sure if I'll have room there yet or not. I may wait until the engine mount is installed before doing this to make sure I'll have enough clearance.
