Brief Description: Install Ground Lead, Trans Oil Line, Approach Hub
Next I installed the oil line for the oil pressure transducer and clamped it to the upper edge of the firewall recess. Since this is a flared fitting, no EZ-Turn was used.I also installed the ground lead from the negative post of the battery to the B&C ground tabs.Next I installed the Approach Systems hub to the cabin side of the firewall.
Ground lead installed, oil pressure line connected to transducer and clamped to recess
Approach systems hub installed on cabin side of firewall
