Brief Description: Install Battery Tray, Battery, and Relays
Today I bolted the battery tray to the firewall. However when I went to install the battery into the tray, I discovered that I had mounted the B&C strip of grounding tabs a little too low and the large bolt interfered with sliding the battery into the tray. I'm not sure if I will end up moving the strip or just deal with loosening the bolt each time I need to remove/install the battery.Once the battery was in I bolted the two relays to the firewall. I still need to install a spike catching diode on the starter relay. I already installed one on the battery relay.
