Dan's Web Site
Date:  1-5-2012
Number of Hours:  0.50
Brief Description:  Right Wing Tip - Redrill Bottom Holes
After clamping the trailing edge surfaces flush with the aileron and having just the top clecoes in I redrilled the bottom holes in the fiberglass I'll be using an aluminum reinforcement strip so that should cover the missed drilled holes on the bottom along with some epoxy filler.
The final picture below has the trailing edge clamp removed. Both the top and bottom clecoes are in. I'm just pinching the slice in the trailing edge together - the surfaces of the wing tip now align with those of the aileron!
Right wing tip - bottom holes redrilled - back view
Right wing tip - bottom holes redrilled - front view
No trailing edge clamp, just clecoes - top and bottom. Top surfaces now aligned.
