Larry Winger's 601XL Project
Date:  9-15-2008
Number of Hours:  2.25
Brief Description:  Drilled Wing Attachment Uprights & installed front
This was a productive night, especially compared to the plodding progress of the last few sessions. Drilling the 5/16" holes to align with the center spar was quite easy using the transfer punch method. After starting with a #40, then #30, I switched to a unibit step drill and moved on up to full size. Things fit perfectly the first time. I then moved on back to the seat assembly by fitting and installing the front seat panels. Enough for one night.
Wing Attachment Uprights drilled in place
Front seat panels in place
Access panels to spar bolts
