Darrel's Kitfox - SS7
Date:  2-24-2024
Number of Hours:  2.30
Manual Reference:  None
Brief Description:  Machined one aileron bell crank
One of the bell cranks that came with the kit apparently missed a final machining step as you can see when comparing the two bell cranks. Tempting fate, I was lucky enough to be able to finish the final machining step and actually ended up with a press fit for the bushing while its sister bell crank required a bit of epoxy to make sure the bearing was securely mounted in place. The picture below shows a bolt holding both bearings in alignment while the epoxy cures.
Incomplete machining operation
After machining; epoxy cures
