Darrel's Kitfox - SS7
Date:  6-3-2018
Number of Hours:  4.50
Manual Reference:  Rudder
Brief Description:  Completed rudder and began HT and elevator
Installed the elevator and elevator to be able to verify the available range of motion for the rudder. Turns out I could file down the stop and get more range.
Also, hanging the elevator on the HS showed some level of misalignment so I spent a bit of time running the source of the issue down so as to be able to minimize the effort needed.
Turns out the HS mounting lugs were pretty straight and not the issue; the elevator was.
Will think the issue through and work on it tomorrow.
