Brief Description: Continued setting control stops
Set up the elevator up and down control stops.
Torqued all jam nuts and applied proof lacquer.
Removed the HT and elevator.
Installed the communication di-pole antenna.
Rerouted the trim drive motor wiring - moved to a port fuselage position to better avoid control linkages and antennas that may cause some level of interference between the wiring.
