Brief Description: Finished wing tips and contoured fuel tanks
Took the next step in contouring the wing tanks; started the job with Super Fill but once I discovered how much material will be used (the profile is way off) I switched to T-88 with lots of micro-ballons and cabosil.
While the first pass (T-88) was curing, I finished fitting the wing tips.
Also, spent the time necessay today to order the wing tip lights - Aveo Engineering Powerburst nav/position/strobe.
