Brief Description: Misc wiring of overlooked items.
Today I discovered some items which I had forgotten to complete the wiring. I had changed the wiring on the fuel boost pump circuit to add a relay for the stick grip switches because of their small wires and high pump amperage. The relay was completed but I had not wired a ground from the panel switch to the FW.
I then decided to remove the pitot heat amber warning LED from my warning light panel and replace it with an "external" D180 EMS warning light. The pitot heat warning was wired to the EMS contact pin #10 and will show up on the EMS. I added a flashing red LED by drilling out the amber led hole to accept the larger panel mount led. One lead was connected to the Hot Battery Bus while the other was connected to another EMS contact wire pin #29 which pulls to ground during an EMS alarm. The external warning LED will flash for any EMS alarm. It should really catch my attention in bright daylight. The flashing light will turn off once the alarm is acknowledged by pushing a button on the D180.
