Brief Description: Zip tied the wires and static tube to the glue mou
After letting the glued on mounts cure for 24 hours, I proceeded to zip tie the wires, antenna coax cables, and the static air tube to the mounts. The zip tying while laying on your back in the tailcone is more difficult than gluing mounts. Oh well, all in day's work!
I sure hope those mounts stay stuck. I really don't believe in drilling holes into the longerons and stringers for adel clamps unless they are definitely needed. Too much of a chance for stress risers and fatigue induced cracks.
Glued and adhesive mounts holding the coax.
Now there are bunches of mounts.
The glued mount on the right will help support the static tube.
