Brief Description: Added glued mounts to support adhesive mounts.
The homemade glue tool was used to put glue on the mount and then put glue on the fuselage skin. After letting the glue sit for two or three minutes, I used the small channel lock plier to stick the mount to the fuselage glue.
Of course, I had to climb into the tailcone to work, therefore, I had a fan blowing the fumes and hot air toward the tailcone openings. I did not remove any foam adhesive mounts. I just added the glued on mounts to support the ones already there. Needless to say it was a time consuming and muscle straining job which caused me to take some IB profen at bed time.
Glue on tool then transferred to mount.
I used a small channel lock to hold mount and transfer the glue.
I left the foam adhesive mounts and added a glued mount.
