Today I finished wiring my Warning Lights panel which is at the top of the middle stack. I ran a ground wire from the "Alternator Fail" red led to the point of FW penetration and then coiled it with the other EMS wires until I install the engine. I then wired the "Start Switch Engaged" green led from the start switch power terminl to the led and then a ground wire to the FW. I shortened the AP servos power wire that connects to the AP power switch which is on the warning lights panel. I ended by wrapping the wires behind the warning lights panel with spiral wrap and zip tied it to a tie mount.
The Warning Lights Panel (from left to right) now contains an Avionics Cooling Fan switch, an Alt Fail red led, a Fuel Boost green led, a Start Switch Engaged green led, an EMS Alarm red flashing led, an AP Power switch, and a panel lights Dimmer knob in the middle. See the picture below.
Warning Lights panel.
View of wiring from the right side behind the Warning Lights panel.
Better view of the wiring behind the Warning Lights panel.
