The WigWag circuit on the Aveo 6 in 1 landing/taxi light system requires a switch to activate. Since I had no more room on the switch subpanel, I had to place it on the right modular instrument panel. It took a while to drill the holes for the SPST switch on the drill press because I didn't want to mess up the paint on the panel.
After installing the switch, I crimped the faston connectors to the spliced wigwag wire from the tunnel area and the FW ground wire. The switch just grounds the wigwag circuit to ground and wigwags the taxi lights.
WigWag switch mounted on the right modular instrument panel.
