Brief Description: More crimping pins for Molex connectors.
While waiting for more wire to arrive from SteinAir and B&C, I have crimped the switch to fuselage connector wires. All power wires are 18AWG with only the strobe wires shielded. The Aveo 6 in 1 will have sync wires for the strobes and wigwag which are just signal wires. I'll use 22/20AWG for these wires. These Molex 150L connectors will accept 22-18AWG wires.
I had to make a small adapter for my Ideal Stripmater stripper tool to connect the wire depth guide that was shipped to me without the adapter. I drilled a 0.20" length piece of a #4 size brad and then tapped it to 40 threads per inch. Needless to say it was hard to handle but it worked. Now I can set the strip length instead of eyeballing. Actually eyeballing works great after you calibrate your eyeball, but for these pins one must strip perfectly.
Molex 150L connector and rectangular pins.
The pin body is rectangular and is held by the crimp plate while crimping.
The right fuselage connector will have 15 pins while the left will have 10 pins when finished.
