Brief Description: Pulled wire from left to right side.
My wire order from SteinAir finally arrived. I pulled wire from the left to the right fuselage connectors. These wires ran through the rib wire holes aft of the carrythrough spar. I will cut one wire and butt splice another wire into it that will run through the spar and to my WigWag switch on the panel. The switch just causes the wigwag ciruit to short to ground and wigwags the taxi lights.
Two other wires run from left to right and are sync wires for the strobes and wigwag. I'll have to cut and splice the strobe sync wire and run it to the rudder strobe light. I call these splices "Tunnel Ties" on my wire labels. I'll have to wait to pull the rudder wire until I get some help. Charlotte is out of town for a few days.
