Brief Description: Pulled more wires for exterior lighting.
Today I pulled six wires from the switch subpanel to the fuselage connectors for the exterior lights. I spent a lot of time on my belly under the panel sweating. The clamps (1/2" Adel) holding the wires are just about full, so things are tight. These wires will connect to the Taxi/Ldg light switch and the Nav/Strobe switch.
I had to rewire the power to some of the terminals because I had changed my schematic. I discovered that some the faston terminals on these Carling toggle switches were loose which is a no-no as far as I am concerned. I removed the switches and called B&C Specialty. They said to return them and I would be sent new switches, no problem. If any others are found loose I'll send them all back and use another brand.
