Brief Description: Rewired boost pump and fuel flow meter.
When I originally wired the power and ground wires to the fuel boost pump I used butt connectors. I have since realized that I should have wired it to be easily removed without having to cut the wires. So I proceeded to rewire using knife splice connectors covered with clear heatshrink. Easy enough except for having to lie on my stomach to reach the wires.
While I was on my stomach I wired the fuel flow meter wires to the EMS harness wires also using knife splice connectors.
Boost pump wired using knife splice connectors covered with clear heatshrink.
