Brief Description: Wired nav/com power & HS34 ground.
Trying to get into the swing of the new year, I went out to the garage and wired some wires. I connected the SL-30 nav and com power to the E-bus each with its own wire. I also wired the HS34 serial laptop harness ground to the avionics ground bus. This harness will be attached to the GPS496 until the need to update the software in the Dynon HS34. It will then be disconnected from the 9 D-sub connector and connected to the laptop serial port to update the HS34.
I finished up by performing continuity checks of the wiring that I had just completed. I'm now in the swing of this new year! Sorry. no pictures.
