Today I changed the wiring to the dimmer module to allow the Hot battery bus to control the panel lights through the dimmer. By rewiring the 2-10 switch, I can now control and dim two different color LED strips that I'll use as my panel lighting. The red/white LED strip will be taped to the glare shield and can be switched to either white or red as well a dimmed. The B& C dimmer module has 4 more positions on the D-sub that I can use for dimming. My plan is to buy the Aveo Touchbeam lights for swivel side panel lights. They have the switch and dimmer built in so I won't need to wire them through the dimmer module.
I also wired the servo power switch to the E-bus and will later wire the power to the servos from the switch. The Dynon EFIS D180 will be used as the master for the servos. Sorry, no pictures.
