Brief Description: Finished scat hose install & worked on cowl.
I finished installing the scat tubing for the cabin heat. I added the short hose from the right inlet ramp to the heat muff on the #1 exhaust. We'll buy and add the 2" SS worm gear clamps tomorrow. I added a SS strap which connects to an adel clamp on the lower diagonal engine mount tube, which should stabilize the long scat tube going to the cabin heat box.
Charlotte mixed some epoxy and microballons to add to the lower cowling at the inlets. She'll sand and probably add some more tomorrow.
I started to add the hoses to the NACA inlet and eyeball vents. Before attaching the hoses we glued some screen at the inlets to keep bugs out of the cockpit. We'll finish adding the hoses tomorrow.
Scat tube added from right inlet to heat muff.
Micro ballons added (under the blue tape) to lower cowl.
