Brief Description: Started adding/replacing engine parts remove for p
Today I started reinstalling engine parts that I had removed while building the plenum. I put the plug wires to #1 & 3 cylinders and immediately found that the plug wire for #1 would rub against the plenum flange. I apparently had cut the right side baffles too low. So I had to elongate the baffle holes that hold the plenum flanges to move the plenum up a bit. Of course, this required elongating quite a few holes. I finally raised the plenum and lowered the wire attachment enough to just clear the inside top of the plenum. It took quite some time filing the holes. Hope it works out OK.
I then installed the overflow tube onto the fuel pump and ran the plastic hose to the aluminum tube bent to go under the lower engine mount and through the #12 hole that I drilled through the bottom FW flange. Hopefully the oveflow fuel won't impinge onto the closeby transponder antenna on engine shutdown.
Reinstalled the plug wires.
Fuel pump overflow tube installed.
Over flow tube in hole drilled through the FW flange and zip tied to engine mount per Vans drawing.
