Brief Description: Sanded and added more primer to skirt.
After sanding the surface primer with 220 and 400 grit sandpaper, we realized that the pinholes were still there. We decided that the only way to fill them was to mix a small batch of epoxy with filler and keep it relatively thin so that we could squeege it into the pinholes. We did that and now will have to wait for it to cure for about six hours.
We sanded again after the epoxy cured and found that the pin holes are gone. Yippee!! We'll reprime it again tomorrow.
Filled in the pinholes with a not so thick mixture of epoxy and filler.
