Brief Description: Primed the rear skirt with surface primer.
I sanded the filler in thedog house area until the plug fit nice but not too tight. The primer should fill the area a little bit and will have to be sanded to a good fit.
We used some cheap foam brushes to apply the surface primer to the skirt and put on a thick first layer to sand when it drys for 24 hours. Hopefully it will fill in the pinholes in the filler! Now we wait until tomorrow to sand.
