KENNETH T.'S WEB SITE
Date:  9-2-2009
Number of Hours:  4.00
Manual Reference:  Canopy
Brief Description:  Sanded filler and primed surface.
After curing all night, the this morning I set up a couple of saw horses outside on the yard with a plywood piece to form a table. Using a sanding block with 80 grit sandpaper I sanded the skirt as best I could to what I thought was relatively smooth. I used air pressure from the compressor to blow off all the dust then washed it with water and let it dry.
Charlotte and I mixed a small batch of filler with 6 pumps of resin and hardener then added about 2 scoops of filler. After stiring and mixing we realized that we probably had added too much filler so we had to work fast before it hardened. We let it cure in 95 degree heat in the garage for 6 hours then I sanded it again in the yard. This time I sprayed some gray primer on the skirt so that when I sand tomorrow I'll be able to see the low areas easily.
Filled a couple of areas on the inside.
Close-up view of the filler that has cured.
We put on too much for the first time.
