Brief Description: Fitted frame to bubble and marked latch hole.
I messed around tweaking the canopy frame one last time. I'm waiting to prime and paint the welded areas on the frame until we get the bubble to fit ok. After finally being satisfied that I could not do any better with the tweaking, I removed the frame and set it in the upside down bubble and fit it to the shape of the center tube. I then marked where the latch tube hole would be drilled. I cut the plastic protective sheeting about two inches from all the edges and put on blue masking tape to cover the edges of the protective sheeting so that hot plastic bits from cutting would not get on the bubble.
Enough for this evening, my brother is coming over tommorrow to help with the cutting.
