Brief Description: Finished installing gear mount sockets.
After deburring and primining the mount holes, I reinstalled the mounts again to bolt them in place. Charlotte came in with a picture from Jeff Bordelon's web page that showed the two brake AN tube fittings installed on the mount. Just in time for me to remove the mounts again. I had to clean these mount holes and prime them and then enlarge the holes in the bottom of the fuselage to get the fittings into the mounts from beneath. I'm sure glad she came in before I had all 28 bolts in both mounts all set and torqued. The bolts were hard to reach in the carrythrough spar and it was a real chore to install the washers and nuts. Oh well, all in a days work.
