Brief Description: Continued subpanel angle install.
Today I tried to intall the subpanel cable angle for fixating the panel control cables. I realized that the angle did not have a wide enough flange in the vertical direction to use the adel clamps without using some type of spacer. I therefore, unclecoed it and decided to make an angle with the correct dimensions so that a spacer would not be necessary.
I used some .040 sheet and fabricated an angle with the vertical flange 3/8" wider than the original. I then pop riveted the angle onto the bottom of the subpanel since I could not reach with the hand squeezer or the pneumatic squeezer. The first picture shows the cabin heat cable secured with the adel clamp and no spacer required.
View from underneath the panel of the angle riveted to subpanel..
