KENNETH T.'S WEB SITE
Date:  2-3-2012
Number of Hours:  4.00
Manual Reference:  Self
Brief Description:  Cut out foam wingtip ribs and glued.
The new "outside caliper" tool arrived today so I started taking measurents of the wingtips while clecoed to the wing. The tool was not quite deep enough in the throat so I had to add some extentions, but it worked OK. After writing down all the measurements, I averaged the 3" station widths of the wingtips and then subtracted the fiberglass thickness to come up with widths to plot on the foam.
I cut out two partial cord line ribs and test fitted them onto the wingtips. I then sanded a slight angle on the edges and glued them in using Loctite 300 tube glue (Home Depot) specially made for foam to keep the adhesive from melting the foam. I decided to let the adhesive cure overnight before clecoing the wingtips to the wings.
Logged my measurements and calculated the widths.
The new caliper.
The new caliper.
Test fitted before gluing.
