Brief Description: Riveted the VS rear spar to the other side of the
Still need to receive the tungsten bucking bar to complete the VS. The two rivets on the skin on both sides of the middle hinge bracket of the rear spar can not be riveted square because the rear spar channel, doubler, and bracket are too thick. The rivet through these parts decreases the space so that I can't use the manual squeezer or the cast steel bucking bar. All other rivets were set with the manual squeezer, barely. Will have to drill out those two rivets and use the tungsten bar when it arrives. May still have to modify the tip of the C yoke.
Riveted the rear spar to the VS skin on the other side, except for two rivets.
Left out two rivets 'til the tungsten bar arrives.
