Brief Description: Continuing building the cradle.
After the adhesive cured, I attached the plates to the wingtip cutouts to check to see that I can make the adjustments as planned. I then sanded the plywood using 80 grit sandpaper to rough it up for the flox and epoxy that I will squish between the half cylinders and plywood for good adhesion.
After the flox and epoxy cure, I will shape and smooth the cradle before trying to attach the light cylinder.
