Brief Description: Positioned aileron trim D-sub connectors.
I attached the aileron trim (power & sensors) D-sub connector to the left side wall of the tunnel. After realizing that I didn't have enough wire length to put it where I wanted, I settled on a position just behind the aileron servo and just above the hole that runs the stick wires from the left to the right side of the cockpit. I drilled two 1/8" holes for a zip-tie using the 90 degree drill. Charlotte had to use her small hands to reach under the seat pan to insert the tie because my hands were too big. I connected the power supply and checked the stick trim coolie hats. It worked!
Next up is wiring the D100 EFIS and autopilot AP74 harnesses on the right instrument panel.
The aileron connector just behind the servo.
Closeup view of D-sub9 zip-tied to the tunnel wall.
